F20 and F22 Head compatability
Old 09-08-2013, 07:44 AM
ShocK's Avatar
Default F20 and F22 Head compatability
After a brief search I couldn't find anything, so sorry if this has been asked a couple thousand times already
Is it possible to install an F20 head onto an F22 without any modification? Thanks, ShocK
Old 09-09-2013, 04:58 AM
Banned
wadzii's Avatar
they are interchangable.
the only difference is the 06+ heads dont have the passages for the air pump.
Old 09-12-2013, 07:58 AM
ShocK's Avatar
I thought so, how big are those passages?
Old 09-13-2013, 03:17 PM
donaldmejr's Avatar
So will the dbw head still fit the ap1 block.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Old 09-13-2013, 03:18 PM
Banned
wadzii's Avatar
yes, but you'll get a cel for the air pump unless you have aem ems or kpro, etc.
You'll want to keep the ap1 cams.
Old 09-13-2013, 03:24 PM
donaldmejr's Avatar
Well I have a dbw so it shouldn't be a issue?
Old 09-13-2013, 03:31 PM
Banned
wadzii's Avatar
thats right. the only difference in the heads is the air pump passages. everything bolts up exactly the same.
Old 03-05-2015, 08:52 PM
danhinton's Avatar
So what can be done about the passages on the later heads? Can they be filled? Or just deal with the stupid ass gasket and cover?
Old 03-06-2015, 09:17 AM
06Estukay's Avatar
AP1 and AP2 heads are interchangeable. The major difference is the 06+ DBW heads, which do not have the air passages drilled out.
Installing a DBW head on a pre 06 car requires the air pump to be deleted, since there is no provision to run it.
Installing a pre DBW head on an 06+ requires the passages to be plugged. You can do this one of two ways... Tapping each exhaust port hole and installing a set screw with an epoxy to make it permanent, or, tap the main passage on the back side of the head and install a socket head plug (3/8" works perfect).
Old 03-06-2015, 09:25 AM
Banned
wadzii's Avatar
I usually just weld the ports up... you can drill and tap any number of places, you can even install the cover and gasket and air pump valve on the 06+ manifold.. lots of ways to do it.
Quick Reply: F20 and F22 Head compatability
