buddy club rails + oem weight sensor ,attached together
Good day s2ki members .
a few months ago i installed recaro pole postions in my s2000 2007 model
but as you know you get srs light and the air bags are non functional .
i finally took the time and was able to combine the oem weight sensor from the oem rails with the buddy club rails.
and its working now.
so i am just gonna put some photos of how its looks all togheter
2 of the rear holes on the weight sensors match perfectly with the extra holes on buddy club rails ,and you use the stock bolts
now for the front you may need to extend the hole alittle bit with a drill and use some other bolt of your choice
once you take the sensors apart you you would see it
