soft top drainage
Old 05-24-2013, 05:11 PM
xxmass's Avatar
Default soft top drainage
...is there tubing or channels that i should check and clear?
Old 07-05-2013, 01:46 PM
2003 ap1's Avatar
bump in for answers
Old 07-05-2013, 03:02 PM
XxMerlinxX's Avatar
There are little buckets with hoses attached on either side of the car, right behind the rear interior panels and somewhat below the soft top brushes. If you can poke around down in there with a straightened coat hanger, likely you will unblock whatever is causing the water to not drain. Numbers 17-21 on this diagram.
Old 07-07-2013, 07:15 PM
2003 ap1's Avatar
thanks
Old 07-07-2013, 10:33 PM
XxMerlinxX's Avatar
No problem, let us know if that doesn't fix it.
Old 07-08-2013, 06:01 PM
xxmass's Avatar
awesome! thank you.
Old 07-09-2013, 04:06 AM
Billman250's Avatar
Received 1,338 Likes on 810 Posts
The ends of the rain rail empty water into the black buckets.
The buckets have about a 5/8" tube exiting from them, with a little bar across the hole to prevent large items from going down (like a sink drain)
These holes are commonly blocked with acorns, pine needles, and dirt.
I found one so packed with soil, it had stuff growing in it.
You can put the top down, and using a penlight you can see right into the buckets.
Old 07-09-2013, 10:21 AM
rrounds's Avatar
Could a air chuck blow air from the bottom up the drain hose with low air pressure?
ROD
Old 07-09-2013, 02:34 PM
2003 ap1's Avatar
^^ in for answers
Old 11-20-2013, 04:53 AM
Y0N1P8T5R1F5A4T's Avatar
ROD
Originally Posted by 2003 ap1
^^ in for answers
I dont think so. I forgot where it drains but I do remember that it drains straight to the bottom of the car close to where the side strikes would be.
jonner
12-02-2016 01:18 AM
ValveBounce
10-15-2016 02:53 PM
1.8TsBLOW
02-15-2008 01:29 PM
fto222
05-22-2006 11:26 PM
Quick Reply: soft top drainage
