My rear diff build in progress
Am in the middle of doing the 4,77 final drive on my s2000 rear diff, Am stripping it right down cleaning,powder coating and replace every bearing,and seals. redline diff oil will be put in So it will run sweet a nut,
The removal of the ring and pinion was pretty straight forward the hard bit is the fitting, have to be accurate to 7 microns or it will whine
backlash settings and preload setting all have to be bang on
Honda bearings and seals prices are mental
Shinny Took some scrubbing
Lsd housing cleaning
4.77 pinion bearings to removed and replace with a thinker stack height one
Size difference 4.77 lower of the 2
Thanks buddy, getting seals shortly needs to be delivered in as there NOK seals and deal with honda only very strange seal as it seals 3 areas in one, not sure if meany folk have done this in the uk ?
Razzele, you know any gearbox/diff specialists local to us ? iv got one guy but its supper complex i just would want some on to check over it before putting it on, a heck of a lot of money has went into this "measure twice fit once" comes to mind
Thank guys,
MB I am going to give them a bell and see what they would like me to do either build it up or send it in bits, Much did it cost to get them to set it up (if you dont me asking) What gear did you go for ?
Thanks Raz, Where you from, I watched all you videos lol, Some nice driving and a very well set up S2000 indeed stays completely flat,
Member
Dave, Andy has built a lot of diffs so im sure he will sort you out. He's in tomorrow until lunch. Can't remember what he charged but he's not dear.
