949 6UL Staggered Setup
Old 10-14-2018 | 08:16 AM
brc80's Avatar
Default 949 6UL Staggered Setup
I am on the hunt for new wheels for my 2001. Car is 100% stock and is a weekend driver, with zero track use.
I was interested in a set PF01's but then I saw the 6UL's.
I don't want do any fender work, and at most may lower the car on springs for a very slight drop. Based on the wheel fitment guide I think I should be good, but I noticed the 6UL's have a slightly lower offset than the PF01's. Since most people seem to recommend them as the default wheel to go to for zero fender work. With all that being said does this combo sound workable?
17x8 +48 225/45/17
17x9 +55 245/40/17 or 255/40/17
Thanks for the input.
Old 10-15-2018 | 04:57 PM
dc2-2-ap1's Avatar
Yes, that size combo works great. That was a popular staggered size common with SSR wheels before they chose to abandon the s2000 community.
i ran 17x8 +48 with 225/45/17 and 17x9+55 with 255/40/17 for years- Autox, track events, trips to Deals Gap, and daily duty- all without issue and zero fender work.
Old 10-15-2018 | 07:14 PM
brc80's Avatar
Did the wheels stick out at all? I’m trying to avoid that for sure.
Old 10-18-2018 | 11:01 PM
dc2-2-ap1's Avatar
no. They are close to flush with the fender, but are still slightly inward.
Old 10-19-2018 | 11:04 AM
s2000Junky's Avatar
I concur, good fitment for these wheel spec and tire widths.
Old 10-19-2018 | 12:32 PM
brc80's Avatar
So front is safe with the +48?
Old 10-19-2018 | 01:09 PM
s2000Junky's Avatar
Yes, just make sure you max out the front camber at your stock ride height, as you have heard. You will be between -1.5-2 degrees.
Old 10-23-2018 | 08:59 AM
nodoze's Avatar
How is brembo fitment with 6ULs?
Old 10-23-2018 | 09:11 PM
dc2-2-ap1's Avatar
the 17x9 +55 is bbk friendly for some kits, I haven't heard about the 8+48.
Old 09-16-2019 | 02:42 PM
ArchieS2K's Avatar
how low was your s2 ? Full camber alignment ?
nickoces2k
11-02-2017 10:36 PM
Phill24
08-11-2012 05:52 PM
b_wong
02-01-2012 07:43 AM
s22k000
04-28-2009 01:57 PM
P-CarDriver
01-16-2008 05:10 PM
