Yet another wheel tire fitment question
Hey guys. I have an Ap1 with swift springs (about 1.2" drop) currently running ap2 wheels with 225/45f and 255/45r . My car is a dd/ weekend car. Might do a couple auto x days when I have time.
looking at a set of enkei rpf1 17x9 45 offset with 245width square setup.
my main question is, will these fit without rubbing or would I need to roll the fenders?
second question is will this be a bad setup for a canyon car/dd?
Site Moderator
It is the most common setup. Yes you need to roll all the fenders and relocate the tabs. Fronts may even need a slight pull depending on camber settings.
On you current setup I hope you just made a typo on the rear tire size. Should be 255/40/17. Not 255/45/17.
The car will feel different with the square setup but I don't think it would be bad. Plenty of people daily with a square setup. Be a little careful are the added grip in front does change how the car handles. Tire choice and what sort of weather you deal with can massively effect this. I would hang onto your AP2 OEM wheels to use when weather gets bad.
moefosho (09-13-2017)
Look at either the PF01s or TR C3s or Kosei K8Rs if you dont want to roll, anything with a +60 offset or higher is preferable.
