XXR 527 Wheels.
XXR 527 Wheels.
http://farm4.static.flickr.com/3006/...464af78f_o.jpg
Hi, guys can you please help me if l could fit these wheels on my 2002 Honda S2000? l found this picture on the internet.
17X8.25 35mmm offset.
Do l need to stagger the wheels. What happens when you buy aftermarket wheels and they are not staggered.
Please help.
Jacob
Please help.
Jacob
your fine. just need a fender roll and maybe a little pull. with some neg camber.
and as for stagger, many people say that unstaggered wheels handle better but its all just opinion, although many people will tell you its a fact.
Yo9u do need to make sure on the center bore. The S2K is larger in the front than the rear. You will not be fine on this application without work on the fenders. If you are willing to make them fit you can. When you go with the same size all the way around a larger front sway bar will be needed for best handling.
Im going to be running these pretty soon. The front is 17x8.25 with a +25 offset and the rear will be 17x9.75 with a +25 offset. Xxr527 black chromium. And the tires will be a 225x40x17. Will post pics when i get them one and done
How did they fit on the center bore? Places that i've seen selling them state that the center bore is 73.1mm, is that same as yours? Did they make the front and rear center bore to size or did you need hub centric rings?
