Wut offset on 17's
Wut offset on 17's
I tried a search but i couldn't find anything. I was wondering wut offset on a 17 inch wheel would fit spoon calipers or most other brake kits.
Thanks,
Phillip
Thanks,
Phillip
Depends on the wheel. Weds Sports SA90 17x7.5 +43 front clears with no spacer as does the Black Racing Pro N1 17x7.5 +45.
17x7.5 +48 Prodrive also works with no spacer. So there are a few. In general a low +40s offset clears the Spoon brake kit. If you go any larger of a caliper you may dip into the mid +30 offsets then you will need wider front fenders unless you remain at OEM height..
