Wrong tire sizes
Wrong tire sizes
I just noticed today that the front tires I recently purchased were 225/50/16 on my 01...is this going to have a detramental effect? And how much is this going to effect handling?
Originally Posted by Emil St-Hilaire,May 26 2006, 10:22 AM
More oversteer.Get wider rear tires.or a bigger,stiffer sway bar.
What sizes do you have on the back? If you have 245/45/16 there, handling won't be that much affected. If you have aftermarket 225s back there too, then you may have to dial down your aggressive driving tendencies a bit.
The way I read it was that a s02 205 was a 225 in any other tire because of the large contact patch the s02s have.. I have Fuzion ZRi's all around, 245/45 in the back and 225/50 in the front and handling wasnt affected
Hi, guys:
This brought up one question I have.
For 05 and 06 models with 17 inch stock rims. what's the best set up in terms of front and rear size for handeling and look?
A: stock size - 215/45/17 front, 245/40/17 back
B: 215/45/17 front and 255/40/17 back
what's your preference when replacing stock tires?
thanks
thanks
S2000 was design to run with equal diameters front and rear. If you like to upsize the rear from 245/40R17 to 255/40R17, then you should upsize the front from 215/45R17 to 225/45R17 to preserve the appearance, handling, ride ... without potential problem with ABS malfunction.
