Work VSXX
Work VSXX
I have a set of Work VSXX wheels in the following specs, 17x8 +57 for the front and 17x9 +57 for the back. I want to to use 225 wide tires upfront while 255 tires for the rear. The problem is I have a Project Mu BBK, and it wont clear the wheels in this offset, so i ordered 2 pairs of 15mm wheel spacers, so effectivley the offsets are now +42 all round. I will be dropping it about an inch all round on TEIN Circuit Masters with EDFC's. What is the probability of me rubbing, and would I need any fender work done, front and back?
Thanks for your help.
you should be ok with those offsets: here was my 17x8 front with a 43 offset: 1.5 degree camber in the front with 225. the rear will be fine with those offsets
