Work s1 setup 18x8 +48 and 18x9 +50
Sup s2ki Just like the topic says my new set of work s1 just came 18x8 +48 front and 18x9 +50 rears. What kind of tire setup can I run on these for a meaty look and what size spacers do I need front and rears to make the offset more flush with my fenders. Your help and advice is appreciated. Thanks s2ki!
They will already be flush. Meaty tires and spacers aren't going to go together. The offsets are perfect as is, if you add spacers you are going to rub like crazy or need little skinny tires. Just run a 225/45/17 and 255/40/17. You could run a 235 up front but the 235/40 sidewall is a little small and the 235/45 is a little bit tall. You could squeeze a 245/40 up front with a good fender roll, but then the sidewall may be a tad squishy on an 8" wheel. Post pics when you get them on.
