Work Rims front offset choice
I see people run 17x7 +42 and +47 offset with the Work Emotion rims. Which offset is better for me? Im lowered on Espelir springs and I want to run OEM size 17" tires as well.
-milkbubble
-milkbubble
For OEM brakes 17x7 +47 is the front you want. If your going with a slightly larger Spoon caliper then the +42 is what you want, keep in mind that with the CRs you need a 5mm spacer to clear. Right there you really cant lower it that much due to rubbing issues with your basically +37 front with your 215/45/17 tire.
So 17x7 +47 is what you want.
Hotkidd
11-06-2005 03:18 PM
