Work Emotion CR Kai S2000 Fitment
Hi
Can someone please advise on the safest S2000 fitment for the Work Emotion CR Kai wheels without having to pull or roll fenders or change the camber setup.
I want to run with 18 x 7.5" front (225 tires) and 18 x 8.5" rear (245 tires).
All the websites I have seen show a maximum of 48mm offset for the 7.5" and 43mm offset for the 8.5". The wheel fitment guide suggests a +53mm front and +45mm rear off set minimum for these wheel sizes.
Just wanted to check to see if higher offsets are available as alot of people seem to be running with these wheels.
Thanks
Thanks
Are you lowered? I am at stock height and have been riding on a 17x8 +45 in my rear without any issues. Your setup would be similar if you stay at stock height.
If you are lowered, then you'd probably need to do minor work to get them to fit without rubbing issues.
I am not lowered yet, but want to lower if possible (after the wheels are fitted). Having siad this, I won't lower if i have to modify the fenders.
Would love to speak to someone who has the 18" wheels fitted to find out exactly what offests they went for.
i haven't purchased the springs yet but would like to if no rubbing issue.
thanks in advance!
