Will this work guys?
Old 04-29-2010 | 02:46 PM
Mino8123's Avatar
Thumbs up Will this work guys?
Hey guys will this setup work
STAGGERED
2) 18 x 8.0
2) 18 x 9.0
Offset: +48 f +50 r
Bolt pattern: 5 x 114.3
Old 04-29-2010 | 02:50 PM
Mino8123's Avatar
What tires should I get if I want to get about 1.5" drop with the Tein S-tech?
Old 04-29-2010 | 02:56 PM
Dressed2Kill's Avatar
225/40/18 front and 245/35/18 rear. You may want to think about rolling you fenders or you will rub when cornering hard with a S-tech drop.
Jim@tirerack's Avatar
Former Sponsor
It will work but I would go with 215/40R18 and 245/35R18 for the tires. You still might have to run more negative camber on the rear.
If I can help with the tiers let me know.
Old 04-29-2010 | 02:57 PM
^ those will work great as well.
Old 04-29-2010 | 02:59 PM
Mino8123's Avatar
What does that mean I know it might be a dumb question but what is rolling fenders?
Old 04-29-2010 | 04:29 PM
pd0019's Avatar
your fenders have a little lip on the inside of the wheel well. rolling your fender gets rid of that lip and gives a couple more millimeters to play with with tire size and offset. you can go with a mild roll which will bend the lip back a little bit, or an aggressive roll and get the lip flush with the inside wall of the fender. be careful when you do an aggressive roll, because if its not done right, the paint can crack.
Old 04-29-2010 | 04:39 PM
Mino8123's Avatar
can someone post a pic of this if you guys can please. Thank you.
Old 04-29-2010 | 04:45 PM
1nate7's Avatar
Old 04-30-2010 | 08:04 AM
Mino8123's Avatar
Originally Posted by 1nate7,Apr 29 2010, 03:45 PM
Thank you very much. will any wheel shop be able to do this?
4wheelsoffury
10-27-2011 07:53 PM
nightowl
12-14-2010 02:57 PM
dwedge
12-27-2007 11:36 AM
rioyellows2k
06-21-2007 06:47 PM
Spec_Ops2087
07-23-2006 01:15 AM
