Will they fit!? Help!
I'm currently after some JDM Blitz 01 wheels. Like the title says i need input! Will 16''x7'' (205/45/16R) +32 FRONT and 16''x8'' (225/50/16R) +38 fit the s2k? I know they are similer to stock in height and width but what about the offset? Its not super low but not real high like OEM. Also is it silly to go OEM height and width? I personally like not having unsprung weight AND a lot of meaty rubber.
They would not be similat to the stock height tires. The 205/45R16 is only 23.3" tall and stock is 24.9. They are not even close. The offset is also going to be very low and require some work to make the wheels fit. With the correct size tires and some fender modification you could make them fit.
