will these work?
will these work?
18 X 8 with 225/40-18 on the front & 18 X 9 with 255/35-18 on the rear.
With the Good Year Eagle F1
what do you guys think? I am bout to order these, I know the offset is correct...tirerack even has them as fitting.
Jim? any advice??
Jim? any advice??
Just because Tire Rack lists them as fitting doesn't mean that the offset is correct. It's probably close, and is good enough when you're using close to stock sizes. But when you start going wider the offset becomes more important.
I would find out the offset first before deciding on tire size.
Originally Posted by greys2k,Mar 25 2005, 11:13 AM
anyone??? i want order these today..im not sure the offset the guy didn't say..but he reccommened everythin..tire sizes and all..
Also: are you planning on lowering you car?
If yes...........the wheel offset / wheel width and tire combination become a lot more important for clearance reasons.
Lastly: Some members on the board choose to sacarifice performance by force fitting narrow tires on wheels that are either too wide or have the incorrect offset..........just for the "BLING".........not that that is wrong.....but you have to decide what is right for you.
