Will these wheels fit, and what size tires?
Old 06-09-2005, 10:30 AM
omgvtec's Avatar
Default Will these wheels fit, and what size tires?
17 x 7.0 +38 (Front)
17 x 7.5 +45 (Rear)
Could I use a 215/45/17 and a 245/40/17 and not have any rubbing issues with a slight drop 1-1.5"?
Thanks,
Steve
Old 06-09-2005, 10:37 AM
SIIK2NR's Avatar
pretty bad offsets for the S.
You only savior is the rim widths.... I'm thinking even narrower tires.
Get your offsets as close to:
+55 front
+65 rear
What you can't make up in offset you can compensate with tire width, rim width, camber and rolling fenders.
Old 06-09-2005, 11:20 AM
omgvtec's Avatar
Okay what about this setup:
17x7.5 45mm
17x8.5 48mm
Old 06-09-2005, 11:48 AM
SIIK2NR's Avatar
17x7.5 45mm
17x8.5 48mm
Yes you can make those work... It's not optimal but you can make it work.
Your going to be limited to tire widths and my have to make some other adjustment on the rear.
You essentially just widened the rim width and increased the offset.
Stretch a tire across the rim and you shouldn't rub.
Old 06-09-2005, 02:04 PM
omgvtec's Avatar
So what size could I realistically run on the rear that won't rub? Will a 245 look stretched on an 8.5 wide rim??
Old 06-09-2005, 02:18 PM
SIIK2NR's Avatar
Stock on an 04 is 8" in the rear so 8.5 will actually work well and decrease the sidewall angle which is what you want.
215/45/17 front
245/40/17 rear
might require a roll or camber with your drop but that's easy enough.
Old 06-09-2005, 02:22 PM
omgvtec's Avatar
Sweet, thanks for the info.
Old 06-09-2005, 02:23 PM
omgvtec's Avatar
BTW, whats the offset on a stock 8" 04 rear rim???
Old 06-09-2005, 02:25 PM
Kel
Kel's Avatar
+65
Old 06-09-2005, 03:14 PM
TR-S2K's Avatar
Originally Posted by SIIK2NR,Jun 9 2005, 03:18 PM
Stock on an 04 is 8" in the rear ...
I thought that the width of stock wheels are 7" fronts and 8.5" rears.
Quick Reply: Will these wheels fit, and what size tires?
