Will these rims fit my s2k ?
I just found a refinished pari of veilside rims for dirt cheap but im not sure if they fit
seeing how i just got my s2000 2 days ago i don't really know to much about the details such as wheel offset
the guy said the rims are this 18 x 8.5 FRONT W/ +47 OFFSET; 18 x 9.5 REAR W/+42 OFFSET with a bolt patern of 5 x 4.50 or 5 x 114.3
so will they fit ? my s2000 is a 2001 i dont think that matters though
thanks for your help
if its a 5x4.50 (which i never heard of) then it wont fit. if its a 5x114.3 then ill fit..BUT! u will have to roll ur fenders front and back or just get a wide body kit. post pix of the rims
here is a picture of the rims and its the only one i have..... he said he just had them pro refinished
now when you guys say roll the fenders, would it be easier to do that or just get a wide body kit, because i was planning on getting the veilside v1 body kit but if i need a wide one i'll just look around for a diff one.
you can run 255 tire but there is more of a chance rubbing even with camber and rolled fenders . if you run 245 you will be fine with less camber than the 255.
ok i just found out exactly what fender rolling is and an easy way to do it
after 4 years of owning a muscle car and i had never hear of that term
here is a cheap way to do it i found on you tube, don't mind the weird music
http://www.youtube.com/watch?v=DDTK9IjKIYU
