Will these fit? offset & width, tire size question
Hey, I found a set of wheels I'd like to buy and they are 17x8" wide. They are available in two different offsets, 35mm and 48mm. Would I be able to use either or combo on my S2K such as 38mm front/48mm rear or 48mm all around on all 4 corners? I know this isn't a staggared set of wheels, idealy that would be better but could this work? and if so what size rubber could I run? 225's in the front and 235-245's in the rear?
Thanks
Steve
Thanks
Steve
Thanks for the info! I am not dropped currently at the moment, however I am planning to drop it about 1.3" soon so I'd want to make sure I pick a tire combo that will be sure not to rub. Anyone have an idea as of which would be the best tire combo to go with?
+48 wil work all around..
they fronts will still be "out" a lil farther than wanted
dont do the 35
riley
as per tires..
18x8 +48 rear with a 245 should work. might be kinda close tho
dont do the 35
riley
as per tires..
