Will these fit?
Will these fit?
I tried looking at the fitment guide and found these will fit... BUT what will look better.
OK I have a good deal on a set of rims. Keep in mind I have a 2 inch drop on Skunk2 springs.
17.7 +35 OR +45 In the front
17.9 +35 OR +55 In the Rear
Which Offset is best to go with that will fit with no rubbing or fender flare??
The more flush the better!
THANK YOU!
If you know the tire size that would work well that would be great also!
THANK YOU!
I think you will have to run pretty crazy camber if you were to go with the +35's Especially with the 2" drop. This is not one of the selections on the guide either. Although the 45 and 55 are an acceptable size according to the guide.
This is an educated guess...
