Will these fit?
Will these fit?
Lookin at some wheels but wanted to make sure they would fit.
17x8 +45 Front 225/45
17x9 +45 Rear 255/40
How can i make the rear look more bowed than the front. i dont care if the front is flush, the rear needs to be concaved tho.
That's going to take more than a "lil roll" to fit in the rear. That rear is way more aggressive than the front, will look a bit out of place. No way on the spacer, that will just make things worse. I don't know what tire you are planning on running in 265/35, none exist that I know of.
so a +38 in the rear is possible? with the proper camber and height? Cuz i really would like to have a 38 in the rear with 45 up front. With a 9" wheel would could you run 235's up front and 9.5" 265 in rear?
