will these fit?
will these fit?
two size questions....
will these fit the s2k?
17x9 with 35mm offset 255/40R17 tires all the way around...
also would this size fit?
if all four rims were 17x7 48MM offset
no and no. 1st can work with a flared front fender but i wouldnt recommend it. 2nd is wayy to skinny.
try going with a staggered setup unless you know exactly what a non staggered setup would do to your handling.
Former Sponsor
They are going to stick out of the fender well with that low of an offset. I would not recommend the same size tire and wheel all the way around on the S2K anyway. The handling is going to not be very good with that type of set up.
