will it rub?
will it rub?
i have a ce28 18x8.5 with an offset of 47 on the rear right now with tires 235/40/18 on them. it does not rub at all but if i replace the tires with a 245/35/18 would it rub?? im running stock aligment also. any help would be very helpfull! thanks!
Check within this forum for the wheel/tire fitment, these postings will answer all your questions.
What fits?
Many people have tried many different wheels and tires on the S2000. Along the way, a lot of people have had problems with rubbing. Some had a little rubbing, and some had none. With all of this experimentation, a few things were figured out. The information below is not the drop dead final word of what will and will not fit. Certain things can be done to make something fit that otherwise wouldn't, such as increasing negative camber, running narrow tires, and rolling fenders, but that adds a lot of variability to this equation and thus is difficult to predict. We'll assume the owner has had a proper alignment, uses tires recommended for the chosen wheel width, and hasn't modified their fenders.
Based on successes and failures from many S2000 owners, we can use an offset calculator to figure out what other offsets and tires will work. These are minimum recommended offsets. You can use a higher offset if you want, and you will get additional fender clearance.
For the front:
205 tires: +43 offset minimum (6.5
What fits?
For the front:
xcrazyaenoyx
11-19-2011 03:40 AM
