Will Prodrive wheels fit over Spoon caliper?
Member
Always a difficult question!
I have a CG07-C 17x7.5 ET48 (front) and need to know if the Spoon caliper will fit.
Help apprecaited.
Help apprecaited.
Link below is a topic about fitment on Spoon caliper maybe it helps.
https://www.s2ki.com/forums/index.ph...ic=338881&st=0
The wheel you're talking about is that the GC07-C ?? Can't find anything on CG07-C .
I sent you a PM, but though I'd post this up for everyone to see.
17x7.5 +44 - Weighs ~15.5 lbs (Will clear Endless and Spoon calipers)
17x7.5 +48 - Weighs ~15.5 lbs (Recommended S2000 Front, Will fit Stoptech and Brembo calipers)
17x8.5 +54 - Weighs ~16 lbs (Recommended S2000 Rear, Can also be used for the front for non-staggered setups and will clear all BBKs)
17x8.5 +54 should fit well on the front. I have 17x8.5 +50 Advan RS on the front and I have no rubbing with a 225/45/17, and will probably try out a 245/40/17 next time around. I don't think there will be any fender clearance issues.
Help apprecaited.
Help apprecaited.
^No, but with the larger rotor, the caliper is pushed further away from the center. Concaved wheels will have more clearance when the caliper is further from the hub.
