Will I run into any problems with....
Old 08-08-2005, 09:00 AM
RT
RT's Avatar
Originally Posted by Jim@tirerack,Aug 8 2005, 07:58 AM
The 225/40R18 would fit and should not rub. Stay that way for the best handling.
he plans to lower the front an inch .... it'll rub!
Old 08-08-2005, 08:22 PM
vroooom247's Avatar
I dont mind cutting the plastic lining to avoid rubbing. If I did that would I eliminate the rubbing issue with the 225/40s and 52 offset? Because I dont want it to perform well
Old 08-08-2005, 09:21 PM
RT
RT's Avatar
..... actually, just let it rub till it "cuts" itself through, you'll be fine.
Old 08-08-2005, 11:02 PM
SpeedxRacer's Avatar
I have 18x8.5 with 225's +51 in the front and I dont rub. Im lowered as well... might be the tires im using though.
Old 08-08-2005, 11:28 PM
RT
RT's Avatar
...... ooooooorrrrr, ya drive like a pu$$y .........................
Old 08-09-2005, 06:34 AM
xviper's Avatar
Might be the "aspect ratio" of your tires.
Old 08-09-2005, 07:36 AM
The Toyo T1S is very..what do you call it... lowered friendly lol. The sidewalls allow you to run a little bit more aggressive offsets. I am pretty sure I would rub with some squared off sidewalls like the Yoko Es100's.
BTW ive taken my car through a course.. no rubbing!
And my momma said im not a pu$$y
Old 08-09-2005, 09:47 AM
RT
RT's Avatar
blackbndt
01-17-2012 10:23 AM
formulaofsuccess
03-28-2009 11:49 AM
lazykiwi
04-07-2006 07:00 PM
Ro_Ja Boy
08-07-2004 01:28 PM
RM 4 2
03-18-2003 08:34 AM
Quick Reply: Will I run into any problems with....
