Will I run into any problems with....
Originally Posted by vroooom247,Aug 6 2005, 03:33 PM
is their a way to get the best performance and not rub out of these. diferent offset? different tire size? different wheel width?
thanks
thanks
so you think a 215/40/18 would work fine for the front? What if I got a higher offset for the fronts? Would the car still perform to its optimal performance, or will I notice a big negitive difference? (regarding 18s and in the sizes that Im looking into)
I appreicate you help
What you stated is nearly the same width and offset of OEM 17s. You must be careful about increasing offset too much. There is always the potential of hitting stuff on the inside of the rim/tire, especially during full steering lock.
