Will I rub running these tires on BBS LMs?
Hi,
Im planning on picking up a set of BBS Lms w/ the s2000 fitment, I wanted to know would it rub.
Front:
18x8 +50
225/40/18 on Federal tires
Rear:
18x9.5 +55
265/35/18 on Falkin Zeix tires
I am lowered about 1 ¾ in on H&R coilovers. Thanks guys.
Front:
18x8 +50
Rear:
18x9.5 +55
I am running the same wheels (same offset) and same tire sizes. I am lowered on PSS9's. I would do a front and rear roll if I were you.
Even with a slight roll up front, I still ended up PWN'ing a front fender on a tight turn up in the mountains. Better to be safe than sorry....destroying a fender sucks, trust me.
Scott-
Scott-
I'm on 18x8 +45 and 18x9 +50 lowered a little more than 2" and I rolled fronts and rolled/relocated bumper tab in the rear. 225/40 and 255/35 for the tires.
For reference: http://www.poopftw.com/images/s2kns1.jpg
-Froth
-Froth
i personally dont think it will rub THAT much, but it would still be good to do a roll/ tab relocate in the rear, and to roll up the tab holders in the front fenders, that should settle any issues you might have
i dont know about the fronts as i am lowered less then you, but i run same front size tires and 275-35-18 in the back on those exact wheels. rears need roll + bumper tab relocate then you can run stock camber no rub at all. fronts will prolly need a roll to at the drop you have.
xcrazyaenoyx
11-19-2011 04:40 AM
