Will this fit/ has anyone done this?
looking to put on
ADR-SZ1 wheels however they only come in a 18X7.5 with an offsest of 48
with tire sizes of 245-40-18 rear
215-35-18 front
does anyone have any sugestions or has enyone done anything simmilar where they didnt stager the wheel size and how that affected things
215-35-18 front
I think the wheel sizes are OK, but your tires should be 215/40/18 and 245/35/18. The size you mentioned for the rear would be way too tall.
Are you lowered?
Are you lowered?
Former Sponsor
You really need at least an 8" rear wheel to run the 245/35R18 so I would say it is not a good fit. Your car would also handle better with a little stagger front to rear.
Jim can correct me if I'm wrong here, but you don't have a lot of choices if you can't run a 245 in the rear (Jim's advice.)
You want to be sure you have stagger in your tire widths front to rear. Since you can't run a 245 in the rear, you'd probably want to run a 225/40 or a 225/35. In the front you'd want to use a 205/45, but you'll probably have a lot of difficulty finding tires in that size. So you could try a 215/40, but that's not much of a width difference, so your S will tend to oversteer easily. Other sizes are going to be too short or too tall to work properly.
Good luck. Hopefully Jim will chime in again on this thread.
