will this fit?
will this fit?
ok...simple question, the fronts look fine
the rims is 17 x 7 w/ 50mm offset...
but in the rear, problem. there's a 17 x 8 + 45 mm, and a 17 x 9 + 45...i know its bad, but how bad is it? will either of those rears work?
17x8 +45 will work with a 235/40/17 for daily driving commuting. Anything more than that with over a one inch drop you will have rubbing issues. I would go with the 17x9 but I would stick to above +50 on the offset so you can run wider tires.
Good luck.
Good luck.
i'd wanna run the ap2 sized tires on the rims
215/45/17 front, 245/40/17 rear. i know the front will fit w/out any rubbing issues. But what size should i go with for the rear to minimzing the chances of rubbing? the 8 inch or the 9 inch if i were to go w/ these rims...the highest offset they have in the 8 and 9 inch is 45
Former Sponsor
The best sizes for the wheels you are talking about would actually be 205/50R17 and 225/45R17. These tires are going to keep you in the same diameter as stock with the stagger front and rear.
