Will 17x7,5" +43ET all around fit?
Hi,
hope somebody can help me. I had an incredible offer from Volk Rays. The wheels are ce28n, but the problems is
that I`m not sure if they will fit to my S2K.
The wheels specs are 17x7,5 all around and offset is +43. I have also 225/45R17" tyres for the wheels, so please tell me, will those fit to my S2K. The car has lowered about 2".
Cheers!
Cheers!
The stock wheels have a stagger, meaning the rears are wider than the fronts. 17x7.5 in the rear is an inch narrower than stock. I wouldn't spend money on a nice set of wheels that aren't staggered.
Yes, this is not a Civic. A wider wheel and tire in the back will help give it traction during acceleration due to it being RWD, as well as improve the handling. You want a minimum of an 8" wide wheel in the back. If you look around, most people that want performance run a 17x7.5 or 17x8 with a 225/45/17 tire and a 17x9 with a 255/40/17 if they remain staggered, or a 17x9 setup with a 255/40/17 tire all around if remaining nonstaggered. A 7.5" wheel will severely hamper the abilities of the car. Also, what tires are you using?
