Widest possible tire on a stock ap1
Old 12-06-2008 | 12:59 PM
saxtonsS2k's Avatar
Default Widest possible tire on a stock ap1
what is the widest possible tire i can fit on my stock ap1 rearwithout rubbing??? and what wheel size would be needed including off set??
Old 12-06-2008 | 01:03 PM
Js S2k's Avatar
SEARCH IS YOUR FRIEND!!!
245/45/16 would be the widest I would run safely.
They look slightly bulged. I don't think they make anything wider that will fit right.
Old 12-06-2008 | 02:38 PM
saxtonsS2k's Avatar
sorry let me be more specific... im getting new rims... i want the widest tire possible without rolling fenders... what rims would i have to buy to accomplish this??
Old 12-06-2008 | 02:45 PM
Js S2k's Avatar
Honestly dude USE THE search
There is a STICKY on this!!!
https://www.s2ki.com/forums/index.ph...&f=56&t=342793
As for a specific rim suggestion
ssr type c rs
17 x 9.5 + 65
You could run a 275/40/17 in the rear without rubbing
Old 12-08-2008 | 05:21 PM
BSeriouS's Avatar
245-45-16 if not a stock bridgestone 225-50
Old 12-08-2008 | 07:52 PM
silentdancer's Avatar
get CCW's in like a 17x10+70 or something and you can fit a 275
why do you need so wide of a tire though?
Old 12-08-2008 | 08:32 PM
Js S2k's Avatar
[QUOTE=silentdancer,Dec 8 2008, 11:52 PM] get CCW's in like a 17x10+70 or something and you can fit a 275
Old 12-08-2008 | 11:12 PM
Voodoo_S2K's Avatar
Originally Posted by Js S2k,Dec 8 2008, 09:32 PM
why so wide?
the fastest s' have done it on either a 255/40/17 non- stag or 255 rear staggard setup.
While the 255 non-staggered is very popular in the JDM circle, there are plenty of fast S2000's running with NASA or SCCA that run tires way larger then 255.
Old 12-09-2008 | 04:18 AM
Jim@tirerack's Avatar
Former Sponsor
I would say 255/40R17 would be a good size. You will need the correct offset to run it without rubbing. I have seen some 275/40R17 as well with some high offset wheels and possible fender lip roll and negative camber.
Old 12-09-2008 | 04:56 AM
Flite's Avatar
With a high enough offset, a 275 is totally possible without rolling fenders or running lots of camber. I like the "look" of a wide tire as well so I think I know where he's coming from.
OP- If you run a wheels that's around 10.5" wide with a +65 or so offset, you'll be able to safely run a 275 tire easily. A 285 is possible as well actually. You just really have to be careful of tire height when you start going that wide.
Quick Reply: Widest possible tire on a stock ap1
