Wider tires and VSA
Old 01-20-2014 | 03:46 PM
marar's Avatar
Default Wider tires and VSA
I have a 2007 with completly stock hieght, suspension and wheels. I read that changing the width of the tires will effect the VSA.
Any truth to that? What size tires can I go with if I am looking for a wider contack patch? I do not want to change anything from stock except the tire width.
Any recommendation on tires? I have no intension of doing track days.
Old 01-20-2014 | 04:06 PM
Manga_Spawn's Avatar
Site Moderator
Just do a 255 in the rear. That's as wide as you can go. Fronts leave at 215. If these sizes are ok on the CR I would expect them to be fine on an 06+ Ap2.
Old 01-20-2014 | 05:37 PM
mmhm's Avatar
i run 245/40 on 17x9+45 all around & dont have a problem
i have friends who run 255/40 square on 17x9+45 or 17x10 & vsa hasnt been an issue for all of them
& yes these are all on 06+ years
Old 01-20-2014 | 05:40 PM
RedCelica's Avatar
I have an 07 as well and run 225/45 f and 255/40 r...no issues here
Old 01-21-2014 | 09:42 AM
marar's Avatar
Thanks for the feedback.
Old 01-21-2014 | 10:16 AM
pmptx's Avatar
225/255 street
VSA on no issues
255 square track
VSA off
Old 01-21-2014 | 11:33 AM
spets's Avatar
Tire width should not be an issue. The problem comes with tire diameter. front and rear tires have to be close in diameter, otherwise the different tire revolution speeds will confuse the VSA system.
Old 01-21-2014 | 02:34 PM
marar's Avatar
I see . So going to an 18"wheel would be a problem?
Old 01-21-2014 | 02:59 PM
nitewing117's Avatar
It will not be a problem if the TIRE DIAMETER is kept consistent, meaning that the tires must be sized properly. e.g., 255/35/18 and 255/40/17 have the same diameter.
kap
01-31-2014 05:18 PM
rrounds
07-30-2011 05:29 PM
RekonEyEz
03-07-2010 01:28 AM
HMSmikesS2K
Orlando
05-21-2008 05:16 PM
skullbang
10-16-2007 12:16 AM
