Widen rpf1 17x11.5 +63 295/35/17 kumho xs
#41
Originally Posted by s2000Junky' timestamp='1413998606' post='23378910
[quote name='SlowTeg' timestamp='1413987704' post='23378664']
[quote name='RedCelica' timestamp='1413982866' post='23378595']
do you think that the structural integrity of the wheel has been compromised at all?
No risk no reward. Cool to see some following in my footsteps and some others considering, not that widening wheels is anything new, but doing it on an S2k with the mentioned tire option, is. Just consider the mentioned reasons for doing this, there is no point if the wheel can be had off the shelf to accommodate an average sized tire that would otherwise fit by other measures. And also consider that this 295 in a 17 may or may not be available in Kuhmos new XS replacement. No other manufacture currently makes a 295/35/17 and the current XS run has been discontinued since 08 with all known replacements now gone off the shelf. The v720 will be your only potential option to run this size tire starting in spring of 2015. so if anyone is considering doing this, wait till then to insure you have a tire.
The better option I think at this point would be to just run 18"
[/quote]
What rim setup are u running in the front?
[/quote]
Started as the convex 8.5" +40. Added 1.5" to inside for a 10" +58. This allows for optimum 255 profile/fitment and a BBK fitment, if I ever run one.
#42
Originally Posted by riceball777' timestamp='1414295269' post='23382916
[quote name='s2000Junky' timestamp='1413998606' post='23378910']
[/quote]
[/quote]
[/quote]
Does the 17x10+58 run on the lower upper control arm when the steering is at full lock? I ask because my oem ap2 rims which are 17x8.5+65 almost rub on the front upper control arm at full lock. It's like a few mm from rubbing.
#43
Originally Posted by s2000Junky' timestamp='1414694827' post='23388299
[quote name='riceball777' timestamp='1414295269' post='23382916']
[/quote]
[/quote]
[/quote]
[/quote]
No, I actually just touch the lower control arm at full lock on one side and about 1mm away on the other with the car up in the air, no issue on the ground. Your cars ride height and alignment both play a sizable factor in this. The car actually increases clearance on the lower control arms as you lower the suspension, and the upper I have no issue at any hight it appears.
#44
If s2000junky has been running this set up for years with no failures nor has anyone on this site recall a failure of this type I would have to say it is an acceptable risk to run this motherf@#ker steam roller meatosaurus.
#46
How wide can you go with ap2 wheels (w/25mm spacers) upfront?
#47
[/quote]
http://ericvaughnmachine.com
That's the place. It's in Monrovia ca. So yes it's in the Los angeles area. You car widen any wheel as wide as you want. But with stock oem front and rear s2000 rolled fenders max size up front is about 17x10+55 and 11.5+63 for the rear. If you want to go wider then you will need to space the wider rims farther out and run wide/ over fenders.
#48
#49
#50
Originally Posted by CrackerMacker' timestamp='1416537444' post='23412804
[quote name='riceball777' timestamp='1416520810' post='23412584']
[/quote]
That's an interesting point. So from what you are saying, when the wheel is widened, the cut is done on +38mm side of the centerline (0mm), and not right at the centerline? Or does not matter where the cut is?
edit: nm i think i get it
So the correct number would 10" +93. How about the second question about going 11" wide and having a 25mm wheel spacer and rolled fenders? Will that work?
