wheel weights fell off
I just got some new Prodrive rims, and everything mounted an balanced a few days ago. Well I noticed the rather LARGE strip of sticky weights sitting on my driveway. I know which wheel they came off of, but I couldn't tell where on the wheel they used to be, no sticky residue or anything.
However, I've driven the car up to 120km/h and I feel absolutely no vibrations whatsoever. The tech who did it said he had a lot of trouble balancing that one rim in particular, and had to use ALOT of weights to get it close. But without the weights, they "feel" fine.
Should I take it back and get re-balanced? Or am I ok?
have them check if the wheel is straight. with my experience, wheels that are hard to balance and take alot of weight usually are bent. i do suggest getting them rebalanced eventhought they feel okay...
also, the weights probably fell off because they didnt clean the wheel properly. secondly, what kind of tires do you have? sometimes a tire can be out of round or have a defect that might make it difficult to balance.
Weights fell off?? Did you take them a dirty wheel or did you use too much Zaino on your wheels? Zaino Z2 clearcoat poish is just slicker than snot on a doorknob and tape weights have a hard time sticking to it.
zeroptzero
11-30-2018 09:40 AM
