wheel and tire fitment?
my buddy is gonna give me a really good deal on some evo 9 wheel and tires....just wanna know if theyll fit without having to roll the fenders??? dont know how wide the rims are but the tires they have are 235/45/R17 all the way around...thanks!!!
I think the offset on those are +38, so you may need some camber or a fender roll or even both... plus the tires will be a bit on the tall side. Not terrible, but your speedo will be off a few MPH.
well i ended up picking up the evo9 wheels and tires they are Enkei RPF1 17x9. i did a test fit and they mounted up beautifully!!! the bad news....the tires were 255 40 17 racing slicks so i cant use them for DD. anyways as i said before the oem tire is 235 45 17.....my question is can i fit 225 45 17 tires instead to the 235??
In a 235 width, you would want a 40 aspect ratio. 235/45-17 is a bit tall, more likely to rub. 225/45-17 is a bit narrow for a 9" wheel, and might not be any less likely to rub than a 235/40-17.
I'd probably try 235/40-17 fronts and 255/40-17 rears, but you still might want to run a fair amount of negative camber and might have to roll the fenders.
AP1ChowFunon yes they are RPF1 that are evo 9 specs. they put this black plastic ring on 2 of the wheel bores dunno if they went on the front or the back on the evo but these fit on the the back on the s2k the other 2 dont have this black ring so these fit in the front.
ZDan, i appreciate the tire info!!! dont think ima stagger tho....think ima do 235 all the way around.
Only benefit to running 235 all around is that you can rotate front/back, but then you'd have to swap the centering rings as well.
