wheel/tire combo
wheel/tire combo
i just ordered a set of wheels. enkei RPF1 in the following size/offset:
F:17x8+45
R:17x9+45
i've done plenty of research on this setup and have everything figured out except the tire size. right now i am running a buddy club N+ coilover and lowered the car approximately 1.25 inches. i am having my rear fenders rolled prior to wheel install, and i am going to re-align my car with some more negative camber.
i just wanted to see what everyone thinks of the tire size i plan to run, and whether or not it will work. i dont mind the occasional rub, but i dont want it to be rubbing everytime i hit a road imperfection. i was thinking of:
F:225/45-17
R:255/40-17
alternate choice of course would be:
F:215/45-17
R:245/40-17
i'd really like to run the thicker rubber setup. . .anyone successully using this setup with little to no rubbing issues?
F:17x8+45
R:17x9+45
F:225/45-17
R:255/40-17
F:215/45-17
R:245/40-17
Former Sponsor
I would say you are going to be a lot saffer with the 215/45R17 and 245/40R17. The 255 in the rear is going to need some help to fit without rubbing. We are going to be carrying the Enkei wheels. We have the RPF1 in 17X7.5 and 17X8 in stock actually now.
. . .now i just need to find a 17x8+45 with a 225 to test fit the front.
I want to order these in the same size/offsets if they are available soon. But for tire size I would like:
235/40 front
245/40 rear
I think I would be pushing it in the front with a +45 offset, but I want the widest tire possible and maybe I will have a little more breathing room with a 40 sidewall. The lowest I would drop the car is an inch
235/40 front
245/40 rear
If you want to run a 235 up front, you will need to raise your ride height.
It appears that you are lowered and if that is the case, you will definitely rub.
If you want to run a 235, you can do so with AP2 wheels. You can also do this without rubbing and chunking your tires.
