Wheel Size Question
Wheel Size Question
Don't know if this question has been answered previously or not. I have a chance to pick up a set of Moda's from a friend's RX7. They are 17 x 8.5 with a 60 mm offset and have 235.45.17 rubber. Notwithstanding the "factory stagger" controversy, will these rims fit my un-lowered S2K?
Dom, try here. Great link that should help.
http://www.venommotorsports.com/howto/whee...eldiameters.htm
Former Sponsor
The wheels are not hub centric for the S2000. You also don't mention if there is a narrower wheel for the front. I have heard of people using this high of an offset but it is not something we recommend for the car but you may be able to make it work.
I hope this helps some.
Jim 800-428-8355-364
The wheels are all 8.5 in. wide. Tire AND wheel inboard increase in front is 1.8 inches and, for the rear, 0.5 inches. Outboard increase front is 1.4 in. and rear is 0.9 in. As I said, I'm really concerned about the fronts. I question if there is nearly two inches inside clearance, and what about the 1.4 outside? Do you have any clearance data for the S2K?
regarding the "controversy", don't ignore it. its not really a controversy. I think you really dig the wheels you are trying to aquire and trying your best to make it work. Several people have gone out and purchased the same sized wheel and mounted them in all four corners only to regret their purchase and very soon afterwards purchase a different set of wheels because it doesn't work.
I can't imagine there would be nearly two inches of strut clearance from an OEM wheel on any car but that is purely assumed. I'm not even sure there is a half an inch clearance (haven't checked) in the rear. I wouldn't go that far outboard on the fronts otherwise you're going to be repainting the side of your car once every six months from road vomit being slammed into it from the tires with that kind of outboard difference (1.4-inches). I just don't think with all things considered, this is a wise choice for a replacement wheel. The measurements are too far from OEM.
