Wheel offset question
Old 06-16-2014, 09:42 PM
Member
Spotter
kryptonite's Avatar
Originally Posted by Manga_Spawn
Small bumps aren't going to do anything. You also ignored the fact that your front tires are the wrong size. You also didn't post the actual offset of the wheel. But I guess you are fine hearing I told you so when it damages your car.
Assuming his offsets aren't crazy, curious to know why the front tires are so "dangerous" The tire walls aren't really that much thinner. Beyond maybe a harsher ride and his speedo not exactly reading accurately, I don't see the harm
Old 06-16-2014, 09:45 PM
Kguy17's Avatar
My apologies, offset is +40.
Old 06-17-2014, 08:08 AM
Site Moderator
Super Moderator
Manga_Spawn's Avatar
The smaller sidewall probably has a lower load rating which could be to low for the car I don't know because he didn't say what tires they are. These tiny tires can also cause the car to oversteer. 10mm difference is pretty significant which is the difference between 215/35 and 215/40. The fenders should be rolled with a +40 offset as well even at stock height especially if you have a difficult driveway. When that front wheel is turned and the suspension compresses you run a high risk of the front tire rubbing and grabbing the front fender. I know this is just another one of those times someone asked for advise and will completely ignore it so it your car ruin it as you see fit.
Old 06-17-2014, 10:58 AM
Kguy17's Avatar
I don't plan on ignoring this info. I am planning on changing my setup(after the inputs), just not right this minute(funds). For now I guess I will drive my other car. Thx for all the info
Old 06-17-2014, 12:01 PM
1nate7's Avatar
I don't think it's that big of a deal at stock height to where you can't drive the car, especially with the narrow and undersized diameter front tire. I would go 215/40, 245/35 on your next set. That would keep stock width stagger and same diamter front/rear. What you have now is an undersized diameter front tire and oversized diameter rear tire. You may want to run a little more negative camber than stock alignment, it will help with fender clearance and increase handling performance.
Old 06-17-2014, 12:20 PM
s2k4life_az's Avatar
Originally Posted by Kguy17
Ok, took a chance and drove it to work today and hit a fair amount of small bumps on the way and there seems to be no rubbing. I'll have to drive with caution I guess, Thx for all the good inputs!
You don't seem that concerned with this reply after posting your question to all of us. I would listen to the advise being given. Under hard compression,high sped bumps, and sudden elevation changes you will most probably have some contact with a +40 offset on your 18" wheels/tire combo even at stock height. You will make contact with your front fender liners and the rear wheels may rub given stock offset is +65. I wouldn't risk it. Either get proper offset wheels, roll fenders, or stay with stock wheels setup. Definitely get the right size tires. It will compromise the handling characteristics of your S2000 like many have said on this thread. Good luck.
blackbndt
01-17-2012 10:23 AM
UR_UP
01-22-2009 05:57 AM
MuckaLun
03-07-2007 10:19 AM
wannabuy
04-04-2006 08:49 PM
dxlst
05-15-2003 03:20 PM
Quick Reply: Wheel offset question
