Wheel lock compatibility?
Hey guys,
I have an old set of Honda OEM wheel locks from my long departed 1989 Honda Accord. Before I untorque one of the lug nuts on my S2K to try it out, does anyone happen to know whether they would be compatible?
TIA!
TIA!
By the way, in case this helps anyone.... the locks are compatible. Local Honda parts dept confirmed the pitch, I tried them out, worked perfectly!
That's good to know..I wonder if the same would apply for a set of McGuard wheel locks I bought for my Honda Fit. I'm not using them on the Fit so I was not sure if they'd fit ok on the S2K wheel studs as well..
I believe most Honda studs are the same thread and pitch. The only thing with open ended Honda locks is that they are designed to sit under a cap. They still work fine but the stud end is exposed to the elements.
