Wheel list that fits over spoon calipers...
Old 08-25-2023 | 07:52 AM
  #491
KraZe_MY03's Avatar
Originally Posted by azn akira
Likely they just CNC a generic forged blank, like Titan7 and Apex. Whereas Volks forge the face of the wheel in a multi step process. "Fully Forged" should come with an asterick
Not every company that makes Forged wheels uses "mold forging" process like RAYS does. HRE is an example that uses "machine forging" process which is exactly how these wheels are made.
Old 08-28-2023 | 06:55 PM
  #492
azn akira's Avatar
I'm aware and also wouldn't buy HRE wheels
Old 12-04-2023 | 10:47 AM
  #493
Mijae007's Avatar
These specs all fit too:
CE28N 17x10 +44
TE37SL 17x9.5 +40 require a 5mm spacer
CE28SL 17x9 +45
Old 04-16-2024 | 01:10 PM
  #494
antani's Avatar
Originally Posted by Mountain-man
About time I rejoin this thread. A number of years ago, I set out to create a wheel-fitment template similar to the one you find on Stoptech's site.
Today, I completed that project with a lot of lazy procrastination in between the time I started the project. I have proof of concept on my own brakes. The info-sheet done up for Work Wheels that I posted a long time ago was for the Spoon calipers, HOWEVER, it proved to be only a cross section of the middle of the caliper, and did not cover all the areas where clearance would be an issue. I did some reverse engineering and now have a printable PDF to scale, that can be cut out and placed inside any wheel desired to test fitment.
If anyone here knows how to post a PDF here, please PM me, and I will make this template free for public use. Secondary verification would be appreciated as well, as I'm the only one who's verified its proof of concept.
PROOF OF CONCEPT
Attachment 113907
Attachment 113908
TEMPLATE IN USE
Attachment 113909
Where can I download the template?
Thanks
Old 04-29-2024 | 05:37 PM
  #495
KraZe_MY03's Avatar
Thanks
There's a separate thread titled "Spoon caliper wheel fitment template" and it's attached there.
antani (05-01-2024)
Old 04-29-2024 | 05:44 PM
  #496
KraZe_MY03's Avatar
I saw that the only 9" wheel on the list that fit without spacers was the TSW Nurburgring 17x9 +63 and I had the chance to buy a used pair from LeeC's parts so I figured I'd double check if this wheel actually fits.
Good news it does, but I'd say there is max 2mm of clearance here. You are only able to get 7 full turns of the lug nuts with these wheels so if you want to add a spacer to these for more clearance you need extended studs.
Last edited by KraZe_MY03; 09-02-2024 at 06:28 PM. Reason: Correcting misinformation
Old 06-17-2024 | 03:48 AM
  #497
Panman's Avatar
Just checking here (My search-fu is weak and I'm not a trusting soul, I've got a set of the SW388 17" in S2000 spec (17x8.5 +60) and they are advertised as Spoon monocoque caliper compatible.
Does anyone have any real world esperience?
Old 06-17-2024 | 03:50 AM
  #498
Panman's Avatar
Sorry that should read 17x8.5 +55 and "experience"
Old 09-27-2024 | 08:53 AM
  #499
Highline's Avatar
Does anyone know if the Advan RG-4 17x9 +45 will fit over Spoon calipers?
garykoo
05-17-2017 12:20 PM
ronaldng0809
09-01-2007 03:24 PM
midnightmethane
01-28-2007 06:10 PM
xS2K PRODIGYx
10-31-2005 11:13 PM
NiN
08-16-2004 01:43 AM
Quick Reply: Wheel list that fits over spoon calipers...
