Wheel list that fits over spoon calipers...
Old 06-21-2016, 09:24 AM
  #421
1nate7's Avatar
Originally Posted by fizzle
will 17x9 +35 RPF1 clear?
No.
Originally Posted by MrCouch
does anyone know if enkei rpf1 18x9.5 et45 fits over these?
No.
Flat/concave face RPF1 have just about the worst brake clearance of any wheel. You would need a decent size spacer, probably ~15mm.
Old 08-30-2016, 07:50 PM
  #422
nos4you's Avatar
Originally Posted by nos4you
Anyone can confirm how much space is left with Volk CE28N in 17x9 +54's.
Guide says 3mm spacer. Wondering if 3mm spacer is more than enough to safely track.
I'm a little scared running 5mm on stock studs
this does NOT fit with a 3mm spacer.
A 5mm spacer might clear, but it will only clear by 1mm if any.
They do fit AP2v1's with a 20mm bolt on spacer though!
Old 09-01-2016, 11:53 PM
  #423
leo777's Avatar
I now the is old but like to now if volk re30 18x7.5 +50 will clear spoon caliper without spacers
Old 09-12-2016, 10:12 PM
  #424
tkeyyy's Avatar
take your honda key and place it on the brake surface area of the rotor perpendicular with the rotor / parallel with the ground. the spoon caliper is roughly the length of the actual key itself + 2mm of the black Honda piece where you turn the key.
Old 12-12-2016, 04:40 PM
  #425
michaelnyden's Avatar
Would an RPF1 in 17x8.5 +40 work without a spacer? It seems to have spokes shaped like the 17x8 +45...
Old 12-16-2016, 01:43 AM
  #426
Nicroman's Avatar
Hi there,
Can anyone tell if the Volk CE28 17x8" ET48 will fit with Spoon Caliper? With Spacers or Without Spacers?
Regards
Old 05-06-2017, 02:13 PM
  #427
k3ns2k's Avatar
Hi, would regamaster 17x7 +45 fit front? with or without spacer? will it also fit brembo?
Thanks
Old 06-24-2017, 04:36 AM
  #428
yeelai123's Avatar
Volk TE37 17x8.5" ET50 fits without spacers
Old 07-31-2017, 05:57 PM
  #429
ap213's Avatar
18x8.5+38 LM's clear without spacers. Mine are reversed mounted with 5mm shaved off the backpad and still clear without issue.
Old 08-02-2017, 06:22 AM
  #430
Spoon Fed's Avatar
Can anyone confirm - Advan RS2 17x9+63 clears Spoons with NO spacer...
i thought i recently read that someone had this setup...
Quick Reply: Wheel list that fits over spoon calipers...
