what's the most aggersive offset you can run for?
#23
Originally Posted by desmond,Feb 29 2008, 10:01 PM
im running 18x8 front +35 18x10 rear+35
#24
Originally Posted by ZDan,Feb 29 2008, 02:15 PM
A 9" wide wheel with +44mm offset places the outside bead seat at 9"/2 - 44mm out from the wheel mounting plane, that's 70.3mm
A 10" wide wheel with a +56.7mm offset will have the outside lip at the same location as a 9" wide wheel with a +44mm offset. i.e., 10"/2 - 56.7mm = 70.3mm
A 10" wheel with a 60mm offset will have the outside lip 3.3mm IN (greater clearance to fender lip) relative to a 9" +44mm. That's a little over 1/8".
#25
Originally Posted by TryPsi41,Feb 29 2008, 07:24 PM
Thanks for the feedback. So, if I followed right I will be "safer" than the 9+44 as far as closer inside the fender wall?
