what's the biggest tires u can run on OEM rims?
I was just wondering what the biggest tires you can run on the OEM wheels? i am thinking about a new rim/tire setup but if the $$$ isnt there than i will be forced to just go with new tires. Any suggestions would be greatly appreciated. oh i am not lowered at all so i dont have tonworry about rubbing or any of those issues. thanks again.
-Matt
-Matt
hello jim,
Is the height of the tire going to be the same if I use 245/45R16 for the rear? What's the difference with stock size, the width? I would like to use wider rear tires, but would like the same stock tire height, which is best?
thanks
thanks
Originally Posted by Jim@tirerack,Dec 22 2003, 08:50 AM
You can go with 225/50R16 front and 245/45R16 rear no problem on the OE wheels.
Let me know if I can help.
Jim 877-522-8473-364
Can I fit this with no problems/rubbing.....?
And Im looking at getting Direzza Star Spec Z1's again, good choice?
