What wheels for more grip
Hey guys,
I was on the CCW thread and those guys are running some pretty wide tires (285 wide) on 18 inch wheels. I'm debating if I should switch as well as I'd like more grip even if it means going to 18" wheels. Track guys, what setup do you currently have?
- I currently run a square setup 17x10 +55 with 255 tires on all 4 corners.
- The car has rolled fenders (no pull) and they fit great.
- As I'm boosted, I'd like more grip.
- I do track the car on road courses.
OEM fenders or Widebody? You're at the limit for OEM fenders with what wheels are currently available. I'm trying to get 18x10.5 +65 wheels to do 265 square.
Also interesting to note - that a 255r18 stretched on an 18x10.5 wheel is marginally faster and more consistent than a 255r17 on a 17x10. All the ASM gridlife guys are running 18x10.5s.
If you're wide body - go pick up some 18x11 +52 wheels from Apex - run 295 square.
Tirerack did some fairly extensive testing on this. Gonna copy/paste myself from the Apex thread.
Tirerack had a very good test showing how wheel width makes a huge difference even on the same size tire. They did two separate tests.
they tested:
225 on 8" and 9" rims
245 on 8" and 9" rims
Second follow up refined test.
https://youtu.be/6yvCRnZUeX8?si=Kzzi17lRQAIkjVCD
And the first video.
They did
215 on 7" / 8" / 9" rims
225 on 7" / 8" / 9" rims
245 on 7" / 8" / 9" rims
https://www.youtube.com/watch?v=1MDq23scaWw
they tested:
They did
OEM body. Thanks for the widebody suggestion. I do wonder if those Voltex flair on the setup you’re proposed would get full wheel travel.
This is a question for @s2000Junky he fit 295’s under a stock body in the rear. It is possible. You do not want to stuff a 295 on a 10 inch wide wheel. You need at least 11 or maybe 11.5 even. 18’s give a lot more tire options in these sizes. It’s not easy and you’ll need custom wheels like a ccs or at least other options that allow for you to pick specific widths and offsets. The front is a much more difficult challenge and usually needs wider fenders for anything past a 255. With the wheel turning it makes it more challenging.
you can check out his footage on track - https://www.youtube.com/@grips2k845/videos
As far as OEM body, i'm gonna hold out to see what wheels Apex decides to make next. If they don't make a wheel I want, i'm gonna probably look at pulling the trigger on some custom wheels from these guys - BSPK Forged.
they look to have pretty positive feedback for people that have purchased sets for multiple different chassis. https://www.s2ki.com/forums/wheels-t...eview-1218531/
Specs i'm going to order 18x10.5 +70 x4 wheels. I'll adjust the front with spacers to be able to run a square setup on OEM fenders.
If you want to run a staggered setup, you could do 18x11 +70 in the rear with 295s - the rear wheel wells have a ton of inboard clearance.
This is a question for s2000junky he fit 295’s under a stock body in the rear. It is possible. You do not want to stuff a 295 on a 10 inch wide wheel. You need at least 11 or maybe 11.5 even. 18’s give a lot more tire options in these sizes. It’s not easy and you’ll need custom wheels like a ccs or at least other options that allow for you to pick specific widths and offsets. The front is a much more difficult challenge and usually needs wider fenders for anything past a 255. With the wheel turning it makes it more challenging.
