What wheels to buy 18x9 and 18x10 +52 or higher
Need to buy new wheels, already have tires. Looking to keep the cost below $1000 if possible. Any suggestions?
I have 18x10's in the back with +49 offset and the 265/35/18's rub on the outside of the tire (on the fender which is rolled).
I believe I need a set with +52 or higher but I can't find them anywhere.
I'm running 18x9's up front with +45 offset and no rubbing issues.
Those specs aren't bad at all, you should be able to make that work. If the difference is only 3mm then I would dial in a little more negative camber. Maybe you need a better fender roll/tab relocation. The other option is to run a 255 tire instead. What tire size are you on up front?
As mentioned, there really isn't anything available in those widths and higher offsets under $1k.
