What tire size for a +32 setup?
Ok so I am doing it...I wanna join the "ultra low offset club". I will be running a set of Advan SA3's 16x8 +32 all around. I just need to get a tire size for the front and rear. The car is stock height but will be dropped a inch soon. Fenders will be rolled front and rear and the rear bumper tab will also be relocated. Negative camber will be adjusted as needed.
What tire size should I be looking to run?
Also, how much camber am I going to be looking at?
THANKS
THANKS
jim, do you think I could go wider? I may try 225's the first set and see if I could push it wider the next set.
THANKS. I will let you know once the wheels get finished and I need tires. THANKS
