what size tire for these wheels.......
what size tires would you run with these wheels .... 17x7.5 52offset in the front and 17x8.5 59offset in the rear....I plan on dropping the car approx 1" and up to 1.5" ....I was thinking 225-45-17 in the front and 245-40-17 in the rear....is this correct....I know that the diameter with this set up would match the stock set up within 1/10" ......is this wide enough in the rear though to keep the rim protected from a curb for instance?
Originally posted by THAGR81
I'd suggest 225/45-17 front and 255/40-17 rear.
Del
Del
