What series tire would I need...?
Well, 1 in.=25.4mm. Convert the stock wheel diameter into mm. Add to this the sidewall height of the stock tire size which you will get by multiplying the width of the tire by series as a percentage (i.e.225/50 would be 225*.50). This will give the you total diameter of the wheel/tire combination. Then do the same thing with the new wheels and possible tires. You'll want to have as close as possible front and rear total diameter, and you won't want them to differ significantly from the stock sizes or your speedometer will be off.
Originally Posted by S2K 4 ME,Jan 27 2007, 11:43 AM
I was trying to keep it simple for this guy since he already has WAYYYYY to much info...........didnt you read the rest of the thread? I'm sure you really simplified it for him giving him that info.
Originally Posted by zoophagy,Jan 27 2007, 12:54 PM
And I'm sure you really helped him out by giving him incorrect information rather than giving him an explanation on how to figure things out himself. If you wanted to simplify things by saying something like "you want a 45 series in the front and a 40 series in the rear," that's fine, but you shouldn't give blatantly false information. That doesn't help or simplify anything.
I think that the second tire selection would be better. You'd keep the 30mm stagger between the front an the rear, and there is basically no difference in the diameter front versus rear. As a disclaimer, though, I am not running these widths on those offsets, so I can't say 100% that it won't ever rub. I think a lot would depend on how much you are going to be lowering it on your coilovers. I'm sure someone with more firsthand experience can chime in.
You said:
The width of the tire is directly related to the sidewall height, as the sidewall height is expressed as a percentage of the width. I'm not trying to be a dick. I just don't want people to get the wrong info.
Originally Posted by S2K 4 ME,Jan 27 2007, 01:48 PM
I didnt give him incorrect info, I gave him the simplified version since he was already overloaded with info.
Originally Posted by S2K 4 ME,Jan 27 2007, 09:27 AM
I think your definatly overloaded............the "255" number has nothing to do with the sidewall hieght.........That number is the width of the tread.
215/45/17 front and 255/40/17 would be closest to stock ratio on the RT615 if you are looking at contact patch which is much more important than the 30 or 40mm stagger suggested using tire specs. I am running 215/255 falken RT615 and love them. 255 is awefully wide for a 8" rim in the back. You would prob. want to use a 245/45/17 on your 8" rims.
Also, you have fairly aggressive offsets. You may experience rubbing with a 225 in the front and a 255 in the rear.
With your rim widths and offsets, I would recommend 215/45/17 and 245/40/17.
Obviously either set up for tires isn't cheap, I'm just trying to prevent a very costly mistake.
Originally Posted by S2K 4 ME,Jan 27 2007, 07:17 PM
You cant be a dick.................according to your profile you've been a GUEST in this club for less than 1 month, you've had a grand total of 4 post, which are all in this one thread, and you dont OWN and S2k. Since you know so much more about tires than everyone else I'll give ya $20 and let ya come change mine out.
Clearly he has more knowledge about tires measurements than I do, and was the only person to post in this thread a way for me to actually figure it out.
I'm not overloaded with info, I just have too many scenario's to choose from and am trying to not pay for tires twice.
I appreciate your help and prompt response to my thread; but you never know who's behind a username and what background they come from.
EDIT: For my Scion website that I built, since I no longer own one...does that mean I shouldn't post there anymore?
