What is the optimum tire pressure for the S2000?
Old 07-30-2006 | 12:41 PM
Purple Haze's Avatar
I'm running 36 psi on all four stock 04 tires. Could this be harmful?
Old 07-30-2006 | 01:16 PM
bankstreet's Avatar
Mine came from the dealer with 45psi all around
Old 07-30-2006 | 04:17 PM
RARE M5's Avatar
I'm running 34 (cold) all around on OEM tires
Old 07-30-2006 | 04:30 PM
kinetica's Avatar
Did anyone else have to take a double-take at RARE M5's avatar?
Old 07-30-2006 | 04:51 PM
donnys2k's Avatar
Old 07-30-2006 | 09:53 PM
chuhsi's Avatar
cold 32 oem pressure all around on stock re-050
Old 07-31-2006 | 02:21 AM
terahertz's Avatar
34 front 34.5 rear cold re050
Old 07-31-2006 | 03:54 AM
ItsBen's Avatar
Originally Posted by donnys2k,Jul 30 2006, 04:51 PM
I did even though I saw that avator before on the rx7 forums.
What pressure are you guys running on S03?
Old 07-31-2006 | 05:22 AM
mikey k's Avatar
Originally Posted by CaptainMike,Jul 30 2006, 08:35 PM
I think the F1 GSD3's have a softer sidewall than the RE 050's do, so you may want to run a slightly higher front pressure to keep a 'crisp' turn-in.
I did notice the wolly turn in. I'll up the fronts to 34 and see how I go!
Old 07-31-2006 | 01:38 PM
Bolt Upright's Avatar
Originally Posted by mikey k,Jul 30 2006, 11:54 AM
Anyone running these?
Goodyear F1 GSD3 Front-225/45ZR17, Rear-255/40ZR17
I think 32psi might be a bit low for them
IMO not a good choice for the S2K unless you live in monsoon country. Transients are lousy because of the soft sidewall. However, if it rains alot in your area, then you RULE with these tires.
If you gotta have 'em, then I'd push the pressure up to 34-35 psi to improve the responsiveness.
