What is the optimum tire pressure for the S2000?
Old 07-30-2006 | 05:13 AM
Purple Haze's Avatar
Default What is the optimum tire pressure for the S2000?
Hi. I'm wondering what you feel is the best tire pressure for the S2000? I realize that the owner's manual and the door sill specify a certain pressure, is it 32 pounds? But perhaps you feel that a few more, or less, pounds is slightly better. I'd love to hear your opinions.
Old 07-30-2006 | 05:33 AM
Tugz_S2K's Avatar
Banned
For the street and if your on OEm tires use the reccomended pressure on the door sill. Its the best for performance, wear, and fuel economy.
On the track i use hankook RS2s and run 38psi front, 35psi rear.
Old 07-30-2006 | 05:36 AM
SLO S2k's Avatar
I run 37 rear and 33 front.
Setup: 205/55f and 245/45r Yokohama AVS ES100s
My personal preference.....
Old 07-30-2006 | 06:01 AM
negcamber's Avatar
Depends on what kind of tire you are using. Sidewall stiffness is a major factor in pressure selection.
Old 07-30-2006 | 06:22 AM
Emil St-Hilaire's Avatar
Kumho MXs,225-255/40/17,and I normally run 34 all around on the street.
Old 07-30-2006 | 06:58 AM
SpitfireS's Avatar
With the S-02's I'm using "OEM" tire pressure.
Works good!
Old 07-30-2006 | 07:15 AM
Saki GT's Avatar
I run 34 psi front, 33 rear.
Old 07-30-2006 | 07:33 AM
CaptainMike's Avatar
I run 33-34 lbs all around on the street RE 050's
38F and 36R (hot) for autoX
Old 07-30-2006 | 10:54 AM
mikey k's Avatar
Anyone running these?
Goodyear F1 GSD3 Front-225/45ZR17, Rear-255/40ZR17
I think 32psi might be a bit low for them
Old 07-30-2006 | 12:35 PM
I think the F1 GSD3's have a softer sidewall than the RE 050's do, so you may want to run a slightly higher front pressure to keep a 'crisp' turn-in.
